Jahay
06.23.2010, 07:43 AM
i was thinking today, and thought if there was a way or connecting both shock towers with some thin aluminium. THat would help support both shock towers correct?
You could get a long rectangular piece of aluminium, sit it on top of both shock towers (so its stretching from one to another. Drill 2 holes either end so the body posts can slide through and sit in their original place, and mount the shock towers as low as posible to hold the aluminium in place. Wont be pretty but it could work???
I know the shock towers bend a lot, my carbon fibre PRC wing mount which helped strengthen the rear shock tower, broke on a small roll over due to the shock tower flexing so much. I am going to make a replacement wing mount, with a similar design in aluminium when i can be bothered to do it. I may do one for the front while i am at it.
