Originally Posted by JoFreak
Did you allready mount your shock towers together with the front and rear bumpers?
I have a few small problems at the moment and can't figure out where exactly.
yes, but there is a problem with mounting the bumpers. i did get it figured out and you do have to make a couple little mods but nothing too big. its kinda hard to explain so i will post some pics later tonight when i get home from work and can show you.
you need to use the little plastic "Y" pieces that mount to the stock towers that hold the body posts. cut off the "arms" of the Y so you have just a little square type plastic part. then screw that to you ERC shock tower in the holes where it lines up. now you have the holes needed to be able to mount up your bumper. now you may need to drill a hole in your ERC tower or grind away a little portion so you can mount the bumper brace up right. i had to grind away just a tiny, tiny bit for the bumper screw to fit through and put locknut on back side of tower. hardly noticeable and completely un-noticeable when everything is mounted up. anyway, thats what i did essentially but i will post some pics up later so you can see better.
i actually havent mounted the rear bumper yet but got the front all mounted and it looks good.
