mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
06.23.2010, 02:06 PM
I am not sure what to think of what you just said thererererere. Stop frequently to check temps and allow to cool if needed? I should be able to run this truck as I please for a whole lipo cycle and once it hits LVC, THEN I allow everything to cool before I put a fresh set of lipos in and keep going. With the outside temperature being what it was at the time and running non stop for 40 minutes, I expected the MMM to have the fan on and the lipos to be close or at 120 degrees. But I would have been happier if the motor showed 170 or 175, not 200. I'll try a larger pinion next time (gotta wait 'till they get here) and see if the motor temp goes down a bit. I hope it does.
Thanks Neil
No brain, no headaches.
