Jahay
06.30.2010, 05:31 AM
As lonng as i am not violent with the throttle, all should be fine. Look at the guy on here running 14s in his savage!!! His centre diff is fine and had no complaints of his BulletProof diffs blowing...
Tyres will def be a problem. I will probably run the Baja road tyres as they are a little thicker and then do the fishline line mod as well as taping them. Anything and everything to prevent them from blowing off the rim!
