stum
07.04.2010, 11:00 AM
Originally Posted by marzac2 View Post
We've been cutting down the esc tray for years now. We almost always suggest doing this for buggy applications where esc space is limited. We always take suggestions though, thank you. Also, may I suggest using the antenna tube and holder. Spektrum DSM 1 has a hard time working properly if your antenna wire is mixed around other wires and not pointing up. We also recommend using velcro on the battery tray and battery or at least use a small foam pad in place at the bottom of the tray to help keep the battery in place during heavy crashes.
small antenna on the dsm2 allows it to flop and work w/o issues at least on the race track.. so I don't need max range but thanks, funny enough my wires were even in wrong in that pic, I had the brake servo plugged into the bind and the transponder in the aux, lol! Yes I didn't install it yet in the pics (it is now) but I use the 3m dual lock works great, very thin, very light and does a great job holding anything.
