thzero
07.05.2010, 02:17 PM
If you are doing standard Flux stretched, the offset is probably needed; mine started as an XL so it doesn't really need the offset... really I'd recommend getting wider axles as opposed to offset wheels. I don't really care for the Axial wheels, at least the beadlocks; have a set with some BigJoes sitting in a closet.
i was thinking of the same using the Axial 40 series wheels with the proline trenchers - That way i'd still get the offset
