nuz69
nuz69's Avatar
07.07.2010, 06:21 AM
Even in 4S a 1520 would run cooler and better for the same speed, because the widings are exactly the same, the motor is just longer and then has more torque per amp, o you can gear up to keep the same speed as the 2200Kv, and the motor will consume the same current (same 4S same power), but will run cooler.
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
