07.08.2010, 10:03 PM
Have fun with this chassis guys...
Poor weight distributuion will be the first issue, batteries in the back, cmon, who comes up with this crap...
And then you will see the need for al bulkhead/diff cases. The stock parts are not strong enough to handle the addl load of the ext wheelbase and the larger tires most will want to run. The tranny will likely have issues too, if you run the weak azz slipper too tight.
Then you will have diff issues, click click. And with the al cases it will be a PITA to get them out.
So lets recap - azz heavy, diff eating, weak plastic truck. I will make your lives easier and just say go with a lst. Sure you have to make your own ext chassis, but what fun is bolting stuff together? Get some legos, will be easier on the wallet.
