snellemin
2 KiloWatt RACER
snellemin's Avatar
07.14.2010, 04:21 PM
hehehe The What-A-nut is just a inside joke that I have at my LHS and Formuladrc forum. Anything that's ultimate is referred to WhatANut!. Castle also reffered to their stuff related to the sized of "nuts".
The connectors are just pin headers that BrianG uses, but mine are just indivually cut as I use anything from 2s to 6s. This way I don't need to make a bunch of balancing harnesses. And now I can charge my two 4s packs as 8s with serial adapters. Lots of time saving compared when I use to charge them in parallel at 10A.
The FMA pinouts are the same as a blinky, which I also use at times.
here's the FMA link for the Pin Lead connection diagrams
http://www.fmadirect.com/support_docs/item_1254.pdf
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
