What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
07.14.2010, 09:06 PM
Having to use a smaller pinion with the faster motor would (I think) reduce current draw during startup since the motor can spool-up easier. However, the faster motor has a higher no-load amp draw. If that translates into the loaded amp draw then it may cancel out, or even negate, the benefit at start-up.
