Thread: Motor Mount
brushlessboy16
brushlessboy16's Avatar
07.15.2010, 06:19 PM
Before you guys go bashing the mount take the time to assemble it correctly.
The black peice thats steel is what the countersunk screw sits in for the bottom hole and is a machined fit. very nice tolerances.. the top slot in the motor mount is designed for an m3 or m4 screw, when using an m3 screw you use the aluminum spacer over the screw and it sits where the head of the m4 screw would be... the mount has no flex in it once the one top screw is tightened down,
