Originally Posted by Krawlin
It doesn't look like there is any kind of machined lip on that lower hole to keep that steel countersunk washer from going all the way through.....
So if you remove the top screw completely, will the motor just come out of the mount with that lower screw/steel countersunk washer?
Motor comes out, however you cannot pull that plug out when the upper screw is sinched down.
