Thread: Motor Mount
brushlessboy16
brushlessboy16's Avatar
07.16.2010, 12:33 AM
Originally Posted by ZippyBasher View Post
It looks great. I have an older model that got bent. but I dont like that the motor is only held with 1 screw. Why was this new design created? what was wrong with the old setup? yeah it took a bit to set mesh but it was solid... I just bent it back and tapped a hole in the side to try and brace it...well see
But if tapped to 4mm (on motors applicable) it probably would be solid. but I would not trust 1 3mm screw to say an 1520 CC/Neu in
an 8ight truggy...
So how close is that motor to the chassis noW? it looks alot lower than the older 1. should be nice.
Could be very low, but im using the spacer plate that came with it to space the spur from the chassis. do you know the tensile strength of an m3 screw. it will surprise you..
