Jahay
07.16.2010, 07:04 AM
Thank you for the fast response...
1. How strong are these motors are taking abuse? i have basically been running my savage with the slipper tightened all the way so far... Should the motor be fine? As long as i dont land and big jumps on power then nothing should really go wrong correct??? I dont mind my weak point being my pinion as it is easy enough to change, i just dont want to be replacing my f/r diffs and CD spur.
2. i guess having a very small pinion means it will wear very fast... at least that will wear and hopefully wont wear out my spur too quickly...
I was looking at the Novak Pinions, hopefully they should be all gd
