brian015
brian015's Avatar
07.16.2010, 02:16 PM
Originally Posted by mistercrash View Post
.030 will be too thick and too stiff. The valves won't bend up to let the oil flow through. The ones I made are .006. The thinner the better actually but it still has to be just stiff enough to hold it's flat shape when resting and flexible enough to bend slightly to let the oil flow.
You're probably right - i have some thinner lexan I can try.
