07.20.2010, 09:51 AM
I'm pretty sure those are the only two.
Now that they are no longer supporting the radios they should release their firmware for people to modify, turn it into an open source project. The problem is that when dealing with the radio signals you have to worry about FCC regulations, and they probably can't have people just messing around trying to get the firmware to work with Futaba, Airtronics receivers, etc.
it's 2.4ghz, the fcc doesn't care about 2.4. all that would change is the way the signal communicates from the tx to rx, FHSS or DSSS
I believe losi recievers are spektrum compatible? That would make them also nomadio compatible...
