07.20.2010, 10:21 PM
The only way to fix it as this time is to use the Castle Link adapter and hook it up to the Mamba Max via the receiver wire. If you do not have a Castle Link adapter, please give us a call in tech support or throw up a post here, we'll get you setup with a fix.
Our engineers are working on a solution at this time, but it does not appear the controllers that have been updated will work with the side USB port until they are updated via the receiver wire and the adapter chip. If you do have an adapter chip, your updated Mamba Max will connect just fine. Let me know if you have any questions or concerns.
Thomas Porfert
Castle Tech Support
