Thread: 10x15x4
ta_man
07.27.2010, 08:14 AM
Originally Posted by Losi LST2 View Post
i might look into picking one up then. does the aluminum seem like it's good quality?...i don't want to end up buying one if it's not going to hold up...kinda like some other company....cough integy cough
I think anything from King Headz is going to be far superior to anything Integy. Just being made of 7075 instead of the more typical 6061 is a plus.
Interesting thing though: I decided I wasn't going to run my 4X4 until I got a STRC aluminum mount. Having the aluminum mount, I am the only one at my track (out of 20 cars) that has had problems with the center bearing (twice: once it seized and then a second one blew up completely).
A friend of mine suggested that the heat from the motor, being conducted through the aluminum mount to the bearing, caused the bearing lube to thin and run out leading to my bearing failures. That's why I did the mod to the platic mount first. (Also, it was the first time I had ever used a boring head and I didn't want to "experiment" on a $25 mount when I could do it on a $4 mount.)
