07.28.2010, 04:14 PM
OK, imagine a 2s pack. You stack the cells like so for running:
Code:
 (-)======(+) ******* (+)    (To ESC)
On the left is the jumper, on the right are the wire leads to the ESC.
Now, let's say you forget to re-orient the cells and install the jumpers for parallel charging, like so:
Code:
 (to charger)
That will cause a major issue!
