Thread: shorting out?
scarletboa
scarletboa's Avatar
08.02.2010, 06:31 PM
while you're at it, get the cc2200 combo. it comes with the motor as well that is well suited for a monster truck like the revo. you might want to run 4s lipo was well. 3s just doesn't cut it.
edit: your problems are indeed caused by the BEC in the esc not being able to power that servo. you can wire up an external BEC as a bandaid, but you will still have to eventually upgrade to a proper setup.
