08.08.2010, 03:18 PM
Originally Posted by Dj_Sparky View Post
I plan to use Mamba Monster with 6s lipo. Low gearing of course.
Anyhow...
Both the 2 gear on the input shaft and 2 gear on the middle shaft are locked together. The gears on the input shaft are 1 solid unit. :S
The 2 gears on the input shaft are likely one solid piece. The other two gears have to be seperate, as they rotate at different speeds. The non clutch gear is supported by a one way bearing, and the clutch hold the other gear in place. They will be removable, somehow.
