nvtuning
08.10.2010, 04:43 AM
A replacement bearing would be the quickest solution if sending it in is too costly- not sure on the size but the original should pop out if you tap it with a dowel rod an a mallet gently.
I know i could replace the bearing but my rotor is damaged by hitting the can
because of a worn out bearing so only a bearing wouldn't do the trick.
I already check my motor can its still fine its just the rotor and the front bearing.
Shipping my motor to the usa would cost me about 30 dollar so that pretty expensive i think.
greets nvt
rc8te/NEU 2200kv/mamba monster/4cells lipo
savage/castle 2200kv/mamba max pro/4cells lipo
scx-10/castle 4600kv/mamba max/2cells lipo
