93firebird
08.13.2010, 08:04 PM
Originally Posted by Dj_Sparky View Post
Hey, how did you mount the center diff? And what center diff did you use? The standard? And what spur gear? I'm trying to make a GST conversion as well, but not sure on how to mount the center diff! :)
Could you post a few more pics, especially of the center diff setup? I've been asking all around the web for some specifics on how to do this, so I'm hoping you can help! :D
As far as the pins.. I bought a new 23mm adapter set for another car, but I believe I ended up using the pins from that set in the GST. They are really thick and need to be pounded through the hole.
I just made a custom mount based around the Matrix TR mounts, and the one found here on the Monster store for the motor mount. I used some aluminum stock found at Lowes, 1/4" steel brake line for spacers and various hardware found at the LHS. I used the 66t spur from the matrix tr mounted to the center diff out of the genesis trans. I don't know how much more info I can give, it's been a a year or so since I built it.
