Freezebyte
08.15.2010, 04:05 AM
Part 4: DeAnodizing and Steering upgrades
Because I once again have a blue/silver/white color theme for "Frostbyte II" just like the original, I decided it was a must to get rid of the stock, purple Savage anodizing. Luckily, thanks to practicing this on my 5T to get rid of its ugly orange, we can rid ourselves of the boring purple quick and easy!
Enter the easiest and fastest way to removing your ugly anodizing, Greased Lighting! About $8 at my local Lowe's.
A nice half hour dip in this stuff will quickly remove all traces of any anodizing on aluminum. Though this stuff doesn't smell very bad, it is fairly toxic so its best to do this outside and keep your animals from licking it.
After just a few minutes, you can easily see the anodizing being removed. It takes about half an hour and results in a slimy, gray layer on the aluminum that needs to be cleaned off with a sponge or rag. Some aluminum parts will need two baths to get rid of all the anodizing as well as any visual impurities.
After a few hours of soaking, cleaning, resoaking and wiping down, here's our result! Mucho better if you ask me! Some peeps actually polish and buff their aluminum parts like this to a mirror shine. I didn't feel the need or desire as its just gonna get dinged and scratched anyway. At least its not purple anymore.
Next on the agenda is upgrading servo saving spring. I'd heard since my first Flux last year that the stock spring isn't very good at protecting your servo unless you crank it down alot. After removing the stock spring, I can see why, its very easy to compress with the tips of your fingers. Were gonna solve that by putting in HPI's heavy duty spring. This sucker is alot beefier and stiffer! I highly recommend upgrading to it, even if you have the stock steering servo.
Now we need to reassemble the bulkheads and the steering assembly. During which, my next upgrade is to ditch the low end bushings in the steering columns and put in HPI's steering upgrade kit with bearings. I had also heard for awhile that these improve steering quit a bit. Lets find out......
Because im anal about such things, I gave each bearing a nice coating of light bearing oil and wiped off the excess
With the bearings in place, I gave the steering assembly a little try. All I can say is....DAYUUM!!! The difference is night and day compared to the bushings! The steering is so buttery smooth in comparison, its amazing the difference a few bearings can make! $15 well spent!
With the bulkheads reattached to our shiny, non purple aluminum parts, were done here!
