08.16.2010, 01:15 PM
So I got a few small button heads into the exposed holes on the motors. Freeze these will definitely work better than the grubs, in your case they should look pretty slick since they put more holes in that motor that the actual castle neu. Im a visual guy, part of me wants you to rotate between a black oxide screw and a stainless every other hole!
