Thread: Timing advance
Pdelcast
Pdelcast's Avatar
08.17.2010, 11:16 AM
BUT -- in sensorless mode the timing is limited to about 20 degrees of advance -- which is the same as "high" timing in the Mamba series.
In sensored mode, the timing can be set much higher (like "CHEAT" mode --) but the advantage only works with very poor performing motors (like the ROAR motors...)
Most sensorless motors are much less sensitive to timing than the ROAR type motors. So the advantage is very very small to advance the timing -- usually you can do better by running low timing, and using a slightly larger pinion than you can by advancing the timing.
NOTE -- ROAR motors are an exception -- they are so badly designed that they benefit tremendously from timing. Don't make the assumption that a good quality motor will also benefit from additional timing.
Patrick del Castillo
President, Principle Engineer
