kingdomracer
kingdomracer's Avatar
08.18.2010, 08:12 PM
I'm following but what I want to know is; if using the 7950TG and MMP with a 2s setup could you get away with just adding the 10,000uf 10v cap or should you still put in a CC BEC because of the HV servo. If that's the case would changing the servo make then an external BEC unnecessary?
JESUS says "Fix it B4 it Breaks"
