SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
08.20.2010, 02:32 AM
What servo are you running? High powered servos seem to cause trouble with some MMP's. Even slightest servo movement with those servos will cause the bec voltage to drop so much that the reciever turns off momentarily. Unplug the servo to see if you still having the problem with throttle.
Area 52 Ranch Raceway
T.R.C.R.
