thzero
08.29.2010, 11:54 AM
Well, found an issue. The Exotec kit has a wheelbase of 334.9625mm. This is just under the max 335mm for ROAR. Why do we care? Because that makes it 2mm longer than the Slash's (333mm) wheelbase. So for the Exotec kit you basically need a body made for the Slash. For reference the Strike has a wheelbase of 347.58 so its way out there and the body probably wouldn't be a good fit.
The CRC kit has a wheel base of 329.5mm which is about the same size as the standard Blitz (329mm) or SC10 (327mm). So either bodies made for the Blitz or SC10 will fit.
So I'm going back to the CRC kit for the extension to go with the shorter wheelbase as I have a Blitz JConcept Manta body.
