scarletboa
scarletboa's Avatar
09.02.2010, 01:28 AM
Originally Posted by Freezebyte View Post
Sooooo, now it gets even more interesting. We've got HPI with updated documentation stating that 100amps of continual current pull will suffice for Lipo's on the MMM. I coulda swore Castle Creations stated that nothing below 125amps would be sufficient to be reliable and safely run the MMM, especially on 3S power to prevent all the ESC meltdowns we had following the Flux's launch last year.
So, once again, what say you Castle?
http://www.hpieurope.com/manuals/upd...ate_060309.pdf
look at my post higher up on this page........
it pretty much explains everything you need to know. your savage with stock gearing should be run with 150a+ batteries to be safe. 125a batteries can suffice with a stock savage, but your savage has been upgraded to XL size and you can now put more power to the ground, requiring better batteries.
edit: didn't realize this was a new page starter.....look on the last page (pg.19) for my post.
