Jahay
09.06.2010, 07:05 AM
shimmed my axles today, and have some great ideas for a custom roll cage...i was looking at some from Main5t but considering he hasnt got my chassis to build around, i thought i would make my own...
everything is cming together, and i have solved my upper arm problems... i am yet to tap out the sway bar holes
i Had problems with stiff meshing on my front GH Bulkhead... I realised that it was because when i broke a pinion on my BP Diffs, i decided to replace only the pinion rather than the set... they obviously have different wear patterns, which meant that with the tight tolerances of the GH Bulks, the gears were not working smoothly... so i am waiting on my new BP Diffs to arrive...
