09.07.2010, 06:11 PM
Take it apart and check the bearings. If it is making a high pitch whine like a SC, than I would say that that may be the rotor spinning on the inner metal of the bearing. If you pull on the shaft and it has too much give the shaft could have separated from the magnet.
Those are my 2 guesses. If it is the motor that is.
