Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
09.14.2010, 08:42 PM
I was going to look in Hopmeup, glad you found them. Start off with 40wt oil. I can't remember if the red springs are extra firm or soft ? Check the HB website to varify. Get the black springs, they are a great general use spring especially with 35-40wt.
The shocks are a little bit of a PITA to rebuild entirely with that tiny clip on the bottom, dont temps yourself to short cut it, Replace everything included in kit. If you have any problems w/assembly refer to the build sheets on the HB site, everything you need is there.
Your temps will dictate weither moving up in gearing is OK, I'm not fimiliar with your ESC/Motor combo. If you decide on a new pinion The RCMonster has the BEST pinions on the market.
Hope it works well for you.
