radioman193
radioman193's Avatar
Arrow 09.17.2010, 01:11 PM
Originally Posted by big dog 01 View Post
Ok-a lot of "sniping" going on here...but,I am getting some good ideas here.I probably should keep the kit supplied 12 turns/blue EVX2 speed controller-for winter "bashing"...and use a brushless system for the rest of the year.
When "550" motors are being dissed,is that just the ones made by Traxxas?(Or,is it the size in general?) Can 540 motors be used? (singly or in pairs ? )
the size in general
a 550 is a 550
a 550 is better than a 540 .
as a 550 has a cooling fan and a longer armature that will give you more torque and the fan will help on cooling
i have used a 540 in this maxx but it gets Hot FAST! when its offroad and its with out the torque that the 550 offers .
a 12t is a high RPM HIGH amperage motor
a 19t would be good for speed power and current draw is lower
and a 21t is even more power less rpm and uses even less current draw.
i just used a Brushed 550 as it will Better handle water mud and other things in the long run......
plus for bashing and mud and water to replace a 550 motor is only$14 vs your brushless @ $60 to $200.
Just Fix It !!!
I have been into electronics for 30+ years
and am a licensed Electronics Technician for over 26 years now.
  Send a message via AIM to radioman193
