_dV
09.17.2010, 08:08 PM
HPI Alu big bore shocks
If you want to upgrade the shocks to handle the extra weight then try stiffer springs and or heavier oil in the stock shocks first and see if you like the results. They are a fairly decent shock.
If you can add some sort of shock tower support that would help as well as they bend a lot.
