josh9mille
josh9mille's Avatar
09.18.2010, 02:27 AM
Isnt that most of the reason people convert to XL is to help keep the front end down? I really dont think you can compain about not being able to wheelie or correct in-air antics untill you run at least 5s. The 4s you are running is barely enough on a standard flux, let alone an XL. Also if you are using punch control it greatly reduces the ability to correct in the air. Not sure if you are using punch control or not but its just an FYI
