09.23.2010, 02:53 PM
Bondo, I've logged over 140A on a CRT.5 (Medusa 36-50-3300 on 3s) geared for around 35mph. So, yeah, depending on how hard you nail the throttle, and ESC settings, I'm sure peaks over 100A are definitely possible.
BTW: That calc you are using is not factoring in burst currents. I'm sure your average current will be far less than 100A, but if you want to see all currents and respective voltages, you'll need something that can measure in excess of 150A (at the minimum) to give you any kind of true readings.
