09.23.2010, 11:30 PM
The way the unit is designed, a thicker gear should not be interfering with the mesh of the gears in the diff. The spur gear is entirely outside of the diff cup. If you are having mesh issues in the diff maybe there is a shim missing on one side or something... Did you assemble it with the pressure all the way loose?
