slimthelineman
slimthelineman's Avatar
09.25.2010, 10:42 AM
Originally Posted by T-birdJunkie View Post
Then the ESC does not see the current.
If the battery can't supply it, etc etc.
If you open a fire hydrant, and there's only 15 psi at the hydrant, does the hydrant explode?
water is not electricity and is bound by completely different laws, that said using your analagy you forgot load. What if there was something on the other end that wanted 115 psi. Something will give. Again speedos don't push power that is why the are not rated as maxiumum output only max current it can pass on.
