T-birdJunkie
09.25.2010, 08:34 PM
Originally Posted by PBO View Post
It's too basic an analogy
You could always adapt an RC to run on pressurised water...then the analogy is perfect. Electricity is far more complex than water & can't be simplified into hydraulic pressure - sorry just doesn't work
Electricity is not that complex. It's electrons flowing one way through a system. hydraulic flow is really no different than electrical flow. If you really wanted to, you could build a 3 phase hydraulic stator motor and a system to properly feed it.
If you don't understand the analogy because you don't understand fluid dynamics, that's fine. Don't pretend electricity is more complex than fluid flow, though.
The point is, if the battery can't supply the amperage, then the battery can't supply the amperage. People post a LOT about "ripple current" and simply accept it as fact without understanding it (kind of like how people assume fluid dynamics and electrical flow are different), yet nobody has offered a proper explanation.
From how ThunderbirdJunkie understands it, ripple current is from a battery not being able to supply the drawn current, then suddenly supplies it, and stops, and continues that cycle.
Is this accurate?
