Semi Pro
Semi Pro's Avatar
09.30.2010, 07:01 PM
Originally Posted by slimthelineman View Post
anyone else ever notice how crappy/weak the 4x4 slash servo saver is? been fighting on -power push since ive been racing this thing for about a year or so. was doing some matinence/cleaning today and was shocked to see how little force it takes to make the servo saver slip. added some shims to tightem it up but it is still pretty pathetic in my opinion. will probably end up just gluing the stupid thing together but just wanted to see if i was the only lucky one to run into this problem.
looked around and found an aluminum adjustible unit from hot racing (HR) for $30. comes with an aluminum draglink too for less slop. deciding whether or not its worth the money to fix the poor design or just glue it down.....
i picked up the one from ST racing and sofar so good, no problems and the last time i tore the truck down it wasnt showing any ware, i have mine set pretty tight since i am useing a hs7955tg for steering, its overkill but thats what we do here
