_dV
10.01.2010, 09:39 PM
I installed this firmware during the week and gave it a first try this morning (RX8\T8). I was a bit confused about the timing as well. The documentation is ok but could be better.
Braking strength has definitely improved. Seems on par now with the Castle MM. I used the first preset for timing (10% ?) which i think is at least the same amount as i had set on the previous firmware (Timing Advance = 10). Top speed seemed a little slower but throttle response felt more linear which was nice. Motor\ESC Temps were in the same range as before
