Semi Pro
Semi Pro's Avatar
10.03.2010, 06:07 AM
Originally Posted by bent70 View Post
What motormount are you using? I ordered a 1717 and was going to go with mikes mount, but read about fit issues with the big can.
its the rc monster motor mount
the smallest gearing i could get to mesh nicely was 18/44
you can gear lower if you space the diff up alittle and go with a larger spur, with spacers you can run as low as 17/50
i really like the 1717 in the muggy............the muggy diffs are takeing quite a beating, between the heavy beadlocks and my driveing it alot hard i keep brakeing the pins.
my diffs are currently set up 7k/30k/3k
