10.08.2010, 10:27 AM
Thanks for that info!
I use gear tooth counts, not ratios (decreases rounding errors when calculating), so what gear tooth counts make up the XXX-T? I assume since the SC10 has the same ratio as the RC10T that the gears are the same...
