thzero
10.08.2010, 10:54 AM
No idea; double checked the Losi documentation and they don't list the gear tooth counts for the three internal gears. Next time I pull it apart I'll have to remember to count them.
Thanks for that info!
I use gear tooth counts, not ratios (decreases rounding errors when calculating), so what gear tooth counts make up the XXX-T? I assume since the SC10 has the same ratio as the RC10T that the gears are the same...
