Nard Cox
n00b
10.08.2010, 12:27 PM
The air version also should have a 5mm shaft according to the website:
17 Series Air Motor
1717-1500KV
Brushless Air Motor
ONLY $70.00
The 17 Series motors feature high quality oversized bearings, sintered Neodymium magnets, superior electromagnetic design, and rigorous engineering control in our own factory.
The 1717-1500 has 2 flats milled on it. Flat to flat is 46mm. Off the flats the can diameter is 49.5mm. The 1717-1500 will work on the Align Trex 600 with motor mount mods (holes opened up for larger screws to fit holes in the motor).
Shaft 5mm
Diameter 2.0" (49.5mm)
Height 3.4" (85mm)
Wire Connector 6.5mm
Shaft length from motor face 0.8" (21mm)
