crazyjr
crazyjr's Avatar
02.28.2006, 09:39 AM
Hey GriffinRU, I just had a thought allong the lines you are working. You could substitute a smaller Novak in place of the 4400 motor and save some weight? Also could eliminate the magnet and save even more weight, may give you more snap as well from the lower rotating mass. Even further along those lines you could eliminate the windings, because you are not using them and take out even more weight if you wanted to, i think.
