Thread: Real 17mm hexes
LiqrSicc
LiqrSicc's Avatar
10.09.2010, 09:42 PM
Just as I suspected the adapter has a small raised edge that can ride on the inner raise of the bearing if it touches at all. Looks good from the pics, and where you have the "O"-ring looks to be where it should be mounted. Kind of a slight buffer for the wheel to snug the fit when it is tightened up. The color only matters when you have the wheels off anyway since the wheels cover the adapter. Get a little mud on it and you won't notice.
I was thinking about getting a set of the closed hex nuts like ala buggies/truggies but the barrel nut doesnt sit flush with the top of the hex hub so it may not screw on properly. I also noticed there is about 1.25mm of in/out play so I may have to shim behind the pin as well.
XXL 1717
SCTE 1512
XXX-S VTA
DX3R
  Send a message via AIM to LiqrSicc
