jappow
10.11.2010, 06:08 AM
Thanks guys for the feed back. Chad thats a good idea im going to have look into getting longer hinge pins then. Red you are right in line with what I was thinking. I was going to make 2 of the extensions in carbon fiber to sandwhich the top peice made out of aluminum, to center the shock. Im still kinda up in the air if I should go any father enjineering this method, like you said Red about the body posts and the fact is there going to be a benefet. This way it does bring the shocks up higher which brings the COG higher, but you do lose some weight going from 8 shocks to 4. Some times designing your own is kinda a drag, you spend days sometimes couple of weeks just thinking is this a good direction, am I missing anything, should I try it this way................. Well again guys thanks for the info i'll keep you posted
ID:	9420   Click image for larger version
ID:	9421   Click image for larger version
