Jahay
10.13.2010, 06:33 AM
Although i will never be purchasing hyperions again... it doesnt mean that i am not going to repair my current ones... I have found one dead cell, so i will remove and make it a 5s pack.
A friend of mine who also hates hyperion due to bad connection problems has just given my 2x2s 6500mah 35c lipos too.. So i will hopefully get them all working after i take them apart completely and resolder everything up... Which means i will be running 9s Hyperions!!! WOOP WOOP! ONLY IF THEY WORK THOUGH! i may need to hit up linc and ask for advice when putting these back toegehter as i have no idea where to start....
a little update
A few things have arrived in the post...
Thought i would post them up....
My Neu 1520 Motor has arrived but i need to collect it from the Post office and pay a £15.00 customs charge which is annoying! £7 VAT and £8 Handling! talk about rip off on handling!
I have been having problems with my steering failing after large cartwheels etc... The stock HPI Savage tie rod ends are just not strong enough!
I even used alloy ends and you wont believe, but after a cartwheel i inspected the alloy rod end only to find the ball stud had been ripped out from the alloy!!!!!
So this is my new approach... i am also hoping in increases my steering furthur due to the bend as you can see in the pic below.
These are beefy mothers!!!! I cant see them flexing anytime soon! Espeically with my TI Turnbuckles :)
Also my Turnigy lipos arrived from HK! Ordered last tuesday and arrived wednesday after being sent out on friday from the German warehouse... Not too bad!
5000mah 40c 3s Lipos
At least i have some lipos for the time being to keep running
